Обща поръчка (STEIN - раздаване - ъпдейт 2)
Започната от DMitar, 21, Април, 2018, 07:24:33 PM
traycho chilev
Добави и тези  :( моля
1 Light Bluish Gray Cat, Standing with White Chest and Muzzle and Bright Pink Nose Pattern   1 бр
2 Magenta Cherries    10 бр
:D
bbeettaa00
За мен може ли тези:
Green Door 1 x 4 x 6 with 4 Panes and Stud Handle - 60623 – 1бр.
White 1 x 4 x 6 with 4 Panes and Stud Handle – 60623 – 2бр.
Yellow Door 1 x 4 x 6 with 4 Panes and Stud Handle – 60623 – 1бр.
Trans-Light Blue Door 1 x 4 x 6 with Stud Handle - 60616 – 2бр.
Tan Door Frame 1 x 4 x 6 Type 2 - 60596 – 1бр.
Yellow Door Frame 1 x 4 x 6 Type 2 - 60596 – 1бр.
Flat Silver Fish - 64648 – 4бр.
Trans-Light Blue Glass for Train Front 2 x 6 x 2 - 17457 – 1бр.
Trans-Clear Glass for Window 1 x 4 x 3 – Opening - 60603 – 6бр.
Green Plant Brick, Round 1 x 1 with 3 Bamboo Leaves – 30176 – 20бр.
Red Plant Flower Small, 4 on Sprue – 3742c01 – 30бр.
Green Plant Flower Stem – 3741 – 60бр.
Green Plant, Tree Palm Leaf Small 8 x 3 – 6148 – 11бр.
Black Plant, Tree Palm Top – 2566 – 4бр.
Blue Technic, Pin ½ – 4274 – 10бр.
Light Bluish Gray Technic, Pin 3L with Friction Ridges Lengthwise and Stop Bush – 32054 – 10бр.
Black Technic, Pin with Friction Ridges Lengthwise and Pin Hole – 15100 – 10бр.
Black Technic, Pin with Friction Ridges Lengthwise WITH Center Slots – 2780 – 10бр.
Dark Bluish Gray Technic, Axle Pin 3L with Friction Ridges Lengthwise and 1L Axle –
11214 – 20бр.
Black Technic, Axle Pin 3L with Friction Ridges Lengthwise and 2L Axle – 18651 – 20бр.
White Window 2 x 6 x 2 Train Front / Boat – 17454 – 1бр.
Shopping Cart - 225 items / 21 lots
Estimated Weight: 3.67oz / 104.10g
Subtotal (225 items):  EUR 12.13 (~BGN 23.72)
bbeettaa00 - добавено всичко - Shopping Cart - 225 items / 21 lots
8)
cardif - добавено всичко - Subtotal (46 items):  EUR 5.08
COBATA - добавено всичко - Subtotal (131 items):  EUR 11.75
8)
mnachevg
Аз ще се включа с тези
col18-1  1бр.
Elephant Girl - Complete Set with Stand New Complete
Incl. accessories, stand and instruction packed in zipper polybag.
col18-17  1бр.
Unicorn Guy - Complete Set with Stand New Complete
mnachevg - всичко добавено  8)
traycho chilev
Tribal Woman - Complete Set  1 бр Индианката с бебе  :-[ моля
Ако може за мен:
1 - Used - Brown Boat, 14 x 5 x 2 with Oarlocks and 2 Hollow Inside Studs - EUR 0.55
10 - Used - Black Fence 1 x 4 x 2 Spindled with 2 Studs - EUR 0.81
1 бр. - Used - Yellow Flag 2 x 2 Square with Train Logo White on Red Background Pattern on Both Sides (Stickers) - Set 4556 - EUR 0.29
2 бр. - New - Black Road Sign Round on Pole - EUR 0.84
2 бр. - New - White Road Sign Round on Pole - EUR 0.90
18 бр. - New - White Support 1 x 6 x 10 Girder Triangular - EUR 7.20
1 бр. - New - Black Train Motor 9V Decorative Side with OPEN hub points (for RC Train motor) - EUR 0.89
1 бр. - Used - Black Train Motor 9V Decorative Side with OPEN hub points (for RC Train motor) - EUR 0.85
1 бр. - Used Light Gray Vehicle, Tipper End Flat with Pins - EUR 0.99
1 бр. - New - Red Wheel 31mm D. x 15mm Technic - EUR 0.24
Estimated Weight: 5.90oz / 167.34g
Subtotal (38 items):  EUR 13.56 (~BGN 26.52)
cardif
Цитат на: DMitar - 23, Април, 2018, 10:15:02 AM
8)
ок мерси
traycho - добавен. Трайчо, научи УонтедЛист, моля ;)
SGB - добавен - Subtotal (37 items):  EUR 13.44 (~BGN 26.29). Мисля, че 1 бройка от това вече е купена, имаше само 9 броя - Used - Black Fence 1 x 4 x 2 Spindled with 2 Studs
vvass
Бате Митко,
финално.....
4.24 euro, 47 items
Бате Васко - всичко добавено  :)
Сметката излезна (вижте / кликнете на прикачения файл по-долу).
Подсещам магазина има 4.25% пейпал и курса на еврото го смятам на 1.97 за 1 евро.
Начини за плащане:
1. Еконт инфо:  1038 София Левски ул. Княгиня Тамара №40
Димитър Стефанов Иванов, телефон - който го няма на лично съобщение или скайп
- еконт офиси: http://www.econt.com/offices/
*Таксата  е 1.2 %
Важно - който иска да плаща по Еконт, задължително да праща преди да получи поръчката, а не с наложен платеж.
2. Отивате, в който и да е клон на Първа Инвестиционна Банка и внасяте пари по картовата VISA сметка в евро на Димитър Иванов, ЕГН 8008xxxxxx и казвате "захранване на сметка" (без такса).  Не нужно да знаете номер на сметка.
Който го знае ЕГН-то от предишно плащане да действа, а за другите на лично, по имейл или скайп ще им дам цялото ЕГН.
Който има сметка в Първа Инвестиционна Банка внасянето на пари е безплатно. Ако нямаш сметка в ПИБ такса от 4лв (минимум, заиси от сумата).
Поръчки под 40 лева ще плащам аз и на ръка при получаване ще плащате ако получавате пратката лично от мен. За тези, които съм се уговорил - плащане при получаване си остава.
Когато пратите парите, моля пишете ми съобщение (Skype E-mail, SMS, Forum Personal Message) - как са пратени по Еконт, ПейПал, Банка.
