Обща поръчка (3 BRICKS) (Раздаване - ъпдейт часове 3!)
Започната от DMitar, 07, Април, 2018, 10:07:18 PM
DeMonica
Атанас Каприев, гр. София
http://brickset.com/sets/ownedby-DeMonica
traycho chilev
И тези  ;D
1 Magpie  1 бр
2 Teen Groot (76102)  1 бр
3 White Clam, Type 2 - Locking Edge on Inner Lip  2 бр Бели миди  :-[
4 Very Light Bluish Gray Minifig, Shield Rectangular with Stud, Knights Kingdom Jayko Hawk Pattern (Printed Version)  1 бр
5 Green Hips and Legs  1 бр
6 Dark Bluish Gray Plate 8 x 8  1 бр
7 Dark Red Brick, Modified 1 x 1 with Headlight   1 бр
С това приключвам  ::) че се забравих  :o Дано не съм прекалил с търпението ти  :D Пиши колко дължа за момента  ??? моля
traycho - добавено всичко - Subtotal (8 items):  EUR 12.58
traycho chilev
Да се включа и аз:
30 - Used - Light Gray Antenna 1 x 4 - EUR 6.38
30 - New - Dark Bluish Gray Bar 1L with Clip Mechanical Claw, Cut Edges and Hole on Side - EUR 1.28
10 - New - Red Brick, Modified 1 x 1 with Handle - EUR 0.068
10 - Used - Black Brick, Modified 1 x 1 with Headlight - EUR 0.60
10 - New - Blue Brick, Modified 1 x 1 with Headlight - EUR 1.02
10 - Used - Yellow Brick, Modified 1 x 1 with Headlight - EUR 0.604
4 - New - White Brick, Modified 1 x 2 x 1 1/3 with Curved Top - EUR 0.51
6 - Used - Dark Bluish Gray Brick, Modified 1 x 4 with 4 Studs on 1 Side - EUR 0.51
10 - New - Dark Bluish Gray Brick, Modified 2 x 2 with Top Pin and 1 x 2 Side Plates - EUR 0.51
1 - Used - White Brick, Modified 2 x 2 x 2/3 Two Studs, Curved Slope End - EUR 0.05
4 - Used - White Brick, Modified 2 x 4 x 1 1/3 with Curved Top - EUR 0.95
3 - Used - Trans-Neon Orange Brick, Round 2 x 2 with Axle Hole - EUR 0.28
3 - New - White Brick, Round 4 x 4 with 4 Side Pin Holes and Center Axle Hole - EUR 0.77
4 - Used - Dark Green Brick, Round Corner 2 x 2 Macaroni with Stud Notch and Reinforced Underside - EUR 1.46
4 - New - Red Brick, Round Corner 2 x 2 Macaroni with Stud Notch and Reinforced Underside - EUR 0.41
4 - New - White Brick, Round Corner 2 x 2 Macaroni with Stud Notch and Reinforced Underside - EUR 0.41
2 - New - Dark Bluish Gray Chain, 21 Links - EUR 0.71
1 - Used - Black Cone 4 x 4 x 2 with Axle Hole - EUR 0.12
1 - New - White Cone 4 x 4 x 2 with Axle Hole - EUR 0.32
12 - New - White Cylinder Half 2 x 4 x 4 - EUR 7.65
10 - New - White Slope 30 1 x 1 x 2/3 - EUR 0.60
2 - Used - Light Gray Slope 45 2 x 6 x 2/3 - EUR 1.29
1 - Used - White Slope, Curved 2 x 4 x 2/3 No Studs without Bottom Tubes - EUR 0.20
6 - New - White Tile 1 x 2 with Groove - EUR 1.09
6 - New - White Tile 1 x 4 - EUR 0.71
1 - Used - Black Train Base 6 x 34 Split-Level with Bottom Tubes - EUR 4.76
4 - Used - Black Train Motor 9V Decorative Side - EUR 7.82
1 - New - White Wedge, Plate 4 x 2 Right - EUR 0.10
1 - New - White Wedge, Plate 4 x 2 Left - EUR 0.10
3 - New - White Wedge, Plate 12 x 3 Left - EUR 0.38
150 - Used - Light Gray Technic Bush - EUR 5.10
Estimated Weight: 9.38oz / 265.96g
Subtotal (346 items):  EUR 47.35 (~BGN 92.61)
SGB - Subtotal (340 items):  EUR 45.62
добавено всичко без  :-\:
traycho chilev
Я добави такава част че се е счупило още едно  :'(
minichamps
Ако не съм закъснял може ли ли добавиш и това
11291   New
Light Bluish Gray Wedge 3 x 4 x 2/3 Cutout    1бр
24999   New
Light Bluish Gray Wedge, Plate 2 x 2 Left  1бр
24307   New
Light Bluish Gray Wedge, Plate 2 x 2 Right  1бр
JoaoNY
Митко, можеш ли да ми поръчаш тези? Всички по една бройка!
New
Sealed
DJ Code Breaker Minifigure polybag - 40298-1
EUR 8.50
New
Sealed
Dragster polybag - 30358-1
EUR 5.9415
New
Sealed
Fire Car polybag - 30347-1
EUR 4.8535
New
Sealed
Police Water Plane polybag - 30359-1
EUR 5.9415
Subtotal (6 items):  EUR 34.04 (~BGN 66.58
#58
Сметката излезна (вижте / кликнете на прикачения файл по-долу).
Подсещам магазина има 4.25% пейпал и курса на еврото го смятам на 1.97 за 1 евро.
Начини за плащане:
1. Еконт инфо:  1038 София Левски ул. Княгиня Тамара №40
Димитър Стефанов Иванов, телефон - който го няма на лично съобщение или скайп
- еконт офиси: http://www.econt.com/offices/
*Таксата  е 1.2 %
Важно - който иска да плаща по Еконт, задължително да праща преди да получи поръчката, а не с наложен платеж.
2. Отивате, в който и да е клон на Първа Инвестиционна Банка и внасяте пари по картовата VISA сметка в евро на Димитър Иванов, ЕГН 8008xxxxxx и казвате "захранване на сметка" (без такса).  Не нужно да знаете номер на сметка.
Който го знае ЕГН-то от предишно плащане да действа, а за другите на лично, по имейл или скайп ще им дам цялото ЕГН.
Който има сметка в Първа Инвестиционна Банка внасянето на пари е безплатно. Ако нямаш сметка в ПИБ такса от 4лв (минимум, заиси от сумата).
Поръчки под 40 лева ще плащам аз и на ръка при получаване ще плащате ако получавате пратката лично от мен. За тези, които съм се уговорил - плащане при получаване си остава.
Когато пратите парите, моля пишете ми съобщение (Skype E-mail, SMS, Forum Personal Message) - как са пратени по Еконт, ПейПал, Банка.
materhorn
